It's running stupid as I'm currently up in Crestwood and see that esp is closest and have heard of them but need recommendations
I bought a r33 to play with while I'm up here in Canberra and on test drive it was great on pick up of vehical after paying for it it cuts out when u punch and then just boost erratic I have put it down to coil packs and tune as its rich as and has a an apexi air flow metre gauge thing
Could be other things.
How much boost is it running?
The r33 ecu isn't tuneable, so you can't just get a tune.
A tuneable ecu installed and tuned could be close to 2000. You have to decide if it's worth it.
Take it to any of the shops listed and ask for advice. Don't try diagnose over the internet.
Me personally use Trojan for most everything. Labour rate and knowledge is excellent.
I have used ESP for tuning and they're good for me. But as stated stock ECU is not tunable.
Hi Ben well not sure atm I'm currently changing coil packs but have now hit road block was told and verified that my r33 is a series 1 but and bough series 1 spit fire coil pack 450 bucks later and now they don't plug into my harness also have bough a blitz digital boost controller and gauge so will be installing
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
