Well I just got my New Apex Power FC in the mail this morning and I went out pulled to stock ECU and pluged the PFC in. When I turned to key on nothing happend at all. No Check engine light illuminated and the comander isn't lighting up or showing anything at all. I checked the Model # to make sure it's the right one for my car. Crank the engine and it wouldn't start. :(
Is there somthing that needs to be done to the unit before it will work? I looked at the english manule from the Apexi webpage and didn't see any steps I missed.
https://www.sau.com.au/forums/topic/45468-brand-new-pfc-not-working/
dont put it in yourself. It best that the computer is put in by a mechanic and tuned straight away. I know someone that put it in himself with a new set of forged pistons. He drove it for a while untuned and bye bye new forged pistons.
my 2 cents
The plug is going in all the way. I am a mechanic by the way.
It's happened to me before... Just unplug it, check all the pins are still straight, and try plugging it back in again.
If it still doesn't fire up after a few tries, check the power wires going TO and FROM the PowerFC (yes the PowerFC has OUTBOUND power wires)...
Other than that, it could very well be buggered? It's just a straight plug-in, and it should turn on and let you switch off the boost control option (if you're not using the boost controller, you have to turn the option off in the menus, otherwise it won't start properly/idle)
my 2 cents
Err, why pay for a mechanic to do it? IMHO that's just a waste of money since a PFC is essentially a plug and play device.
Sorry, but your friend was just stupid. Driving around on a base map with a rebuilt engine is a silly idea.
LW.
Do you know someone with the same car?
Try it in their and see if it fires up.
When i put my pfc in the engine would turn over but not start and it kept loosing any setting we would change. The solution was to put a new earth into the loom and that solved the problem.
Before the ground was put in the loom did the ECU work? Mine doesn't do anything at all. I tried running a ground wire to the ECU case and it didn't make any difference. So how did you figure to run the wire. Did you have to add an extra wire in the ECU conector?
I installed my PFC - simply unplugged the stock ECU, inserted plug into PFC then screwed the bolt down to lock the loom in. I certainly didn't need to earth it.
As for it being a "Plug and Play" device... sure it'll fire up, and even run enough to allow one to drive around, but the mixtures won't be anything near what is required. I can't see how the fool destroyed his motor driving it like that - if he was driving the car hard then I can, but people who fork out lots of money to rebuild a motor and install an ECU usually know a lot about the product they're paying for.
I've noticed that some PowerFCs uses it's metal case to ground itself.
You can't just have it lying on the carpet, you need to screw it into the bracket in the kick panel which will ground the unit.
Others I have seen have worked fine lying on the carpet, so I dunno?
Dude - check that your AFM is wired properly and the right setting for AFM are there. And also check that your AFM is working OK (ie swap with another one)
I just had exactly the same problem - swapped my AFM out and all good. I just don't know if my AFM is stuffed or my wiring was wrong cause I had a Q45 (didn't work) and changed to a VG30DE AFM (worked)
Good luck :D
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
