Hey guys!
when i bought my r32 gtst with rb25de it never had a charcoal canister, the vent line was simply capped off and i also noticed when you unscrew the fuel cap it never whiffed out air like its meant to and i always had a pretty strong fuel fume smell while driving no matter what windows up/windows down didn't seem to matter.. after a while i thought i would plumb it back in, bought the canister hooked it up correctly and tested it out over the next few weeks, the smell seemed to have gone but then when the windows where down it was stronger then ever...
about a year ago i replaced the fuel pump with a walbro and replaced the fuel lines from the tank to the hard lines and when i got the car i replaced from the hard lines to the filter and then to the rail.. but it still smelt
so i did some more research and found that they have a common leak area with in the compliance fuel restrictor, i pulled that out and found that the sealant they had used had perished, i re-sealed it with sickaflex and it still smelt..
so now bassicly I'm after advice on what steps to take next.. a lot of people have said to replace the o ring above the fuel pump but I'm almost certain that is sealed correctly as you can't smell anything in the boot...
the only thing i can think of it being is the filler neck itself or the vent lines from the tank... I'm pretty much at the stage that i want to drop the tank and replace everything... if anyone has any advice or ideas please let me know and thank you in advance!
https://www.sau.com.au/forums/topic/454775-fuel-smell-while-driving/
Leaky injectors ?
Does it have the PCV connected and works
Does it have a catch can and is that vented to the atmosphere
Is it just running rich. What is the AFR's
Do you smell it when its
- Idling
- Moving
- when it is off (then it's a leak)
I had the same issue with my r33 Gtst. I ended up prying out the fuel neck compliance thingy, cleaning it up and using sikaflex to create a nice new seal for it and refitting it. Now the fuel smell is gone and when I go to fill up at the servo you can hear the pssssshhh sound which would never happen before.
If that doesn't fix it then just replace the fuel pump o ring as its a cheap fix (might need replacing after you changed your fuel pump) this was the cause for my in cabin fuel smell when I had my S15.
What hose did you use when you replaced the lines? Some hoses are just prone to be stinky.
Charcoal canister hooked up correctly? When you say the vent line was capped off do you mean the vent for the fuel tank was closed/blocked off?
I'd replace the fuel pump o-ring, cheap, easy and quick to do, leave the guesswork out of it.
picking up a new oring tomorrow, ill fit it and see how i go,
yep cannister hooked up correctly as far as i can see, i compared it to a mates on
and yes the vent line coming from the tank had a bit of hose coming off with a screw in it hose clamped on
i put the car in the air last night, turned it on and got under couldn't smell or see anything...doesnt gel
most likely this.
heard of this plenty of times and usually is the filler neck leaking. Was the same on mine. I found this gives a really strong smell into the cabin as its so close to ur door.
Move your car out into the sun for a while and then when it is nice n warm go and sit in the drivers seat and look back thru ur wing mirror past the petrol filler port. you will probably see fumes coming out- I could before I fixed my filler neck.
If this doesn't fix it then look into where the lines are going to that used to be connected to the charcoal canister.
Edited by jjman
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
