the mod chip does pretty much everything.. no need for a swap disk either.
goto www.mod-chip.com to look at install instructions .
this chip will only work on the V9/V10 ps2 which is schp - 5000x.
asking price is $55 including postage. this is worth about $200 installed so the chip itself is worth about $80-100.
https://www.sau.com.au/forums/topic/45483-brand-new-neo-12-mod-chip-for-ps2/
well if you have a newer playstation, ( version 9 or 10 ) you can use this chip. its only a 12 wire install which is the smallest amount on all the other ones. if you go to the site thats on the first post you can look up all the info you need
Cyclonus you'll need to use the DUO 2 chip.. you don't need a swap disc, and it's a 17 wire install. the points aren't too hard but if your not good with a soldering iron get a pro to do it, as i found out the hard way with a ps1
pm me for more info
sorry mate but installed chips are about $100 these days (what i charge), nowhere near $200, chips are worth about $15 btw
cheapest i've seen chips for are around $60 - $70 aus.
i've found a cheaper place to get them from so. new price -
Neo 12 V.9 - V.10 ( i have 1 left, might be able to get more ) - $35 + postage
Duo 2 V.1 - V.10 ( i have 1 but can get some more ) - $40
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
