Low Compression On All Cylinders + Excessive White Smoke Out Exhaust
So the cars been at croydon. So far a head gasket failure and scoring in the bores (using their little camera). 1 coilpack has failed. And possible turbo failure (probs the rear). Unsure what has actually caused the failure, weather fuel, coolant, fuel caused it or if many things contributed. And as for my usual maint, ive always made sure all levels were fine before driving. But yeah. They will be pulling the head off and visually inspecting the bored turbos and etc.
Update will be up soon
No idea as for now. Im going up to Croydon tomorrow to have a look as they sent me an extremely costly quote LOL . And new turbos werent on the quote (replace or repair)
See what happens tomorrow
Hope you're prepared to drop a bucket of cash on your car to get it running again. If you've done a fair amount of damage and need to replace a few things, it will cost a fair amount, labour involved also.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
    • Thanks guys - I have been overseas for a hectic many weeks , so haven't had time to chase any of these up.  Some of the suggestions are for 4.1 ratio, which I already have, and a 3.5 at Lonsdale, which is also too tall.  Really looking for 3.9 or even a 3.7 LSD, either with M12 bolts. Will look some more.
