Hey guys I'm looking for an auto electrician in Sydney to find out why the 10A meters dash fuse on my r33 gtst keeps blowing when ignition turned to the on position. I can still start the car but the dash doesn't show any inputs but if i turn the lights on the dash lights turn on so it is getting power. I also lose indicators, but they work when unlocking the car and i see them flash on the dash.
I have searched for any wires that may have been exposed and touching the chassis but no luck. Any suggestions on where to look would be great or Im happy to take it somewhere preferably someone who knows there way around a skyline. Any suggestions for a mobile auto electrician or a shop in Sydney would be great
Thanks in advance.
Well the hazards don't go through the same circuit as the dash (and indicators) so that explains why they work but not the dash. You'll need someone to find the short in the dash ignition power, might take some stuffing around but its not impossible
Cheers mate, I had a play around with it today and i found an exposed wire coming from one of plugs on the gearbox touching the chassis (I changed the clutched recently). This stopped it from blowing the meter fuse. However now the indicators still wont work and my speedo and rpm tacho are functioning very erratically or sometimes not at all. Ill try get my consult cable working to see if the ecu is showing the correct values. I fell like my cluster might have been damages when it shorted. Im not too sure about the indicators though.
Edited by jay089
Update: I had my dash completely out and only my cluster plugged in and read somewhere here that the hazard light switch needed to be plugged in for the indicators to work so plugged this in and the indicators are working ok.
It was to late to test what speed and rpm values i was getting from the ecu but will look at that tomorrow. If all is ok from the ecu then would it appear that my cluster is bad?
If you have fixed the short circuit issue with the chassis then a tacho acting erratically is usually common in skylines. If you have everything wired up and plugged in correctly I would say that could be your other issue.
Thanks for the feedback guys. From the consult cable i get correct readings so it is something to do with the cluster. I put it all back together and the dash seems to be intermittently fixed (Sometimes the tacho will go a bit crazy and stay past 9000rpm). If i hit the dash, sometimes it will go back to normal, i did a search and it seems like a common issue. So i will have a better look at the connections when i get a chance. at least the speedo etc is working so i can driver the car in the meantime.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
