Hey Guys,
just need some advice as im looking at buying an R34 GTT turbo which will supposedly bolt right onto my R33 RB25det without having to change anything.
looking at buying an op6 Turbo but am unsure as to whether this is off an R34 and if it will bolt straight on?
Ive also been told to get the R34 GTT turbo high flowed.
Any help is greatly appreciated.
Cheers.
Yes. It is almost exactly the same turbo. The internals of the OP6 housing are larger than the 21U housing on your std 25 turbo.
A turbo with an OP6 housing is not necessarily an R34 turbo though. The OP6 was also used on VG30 turbos. I suspect the easiest way to tell the difference would be that VGs probably have an alloy compressor and R34s would have a plastic compressor.
For everything you need to know about highflowing these, look at the stickied Hypergear thread.
/searchable topic.
yes, and it's an awesome turbo considering the price tag. Although it doesn't run very well on the standard R33 ecu. I was having issues at 9 psi on the HG 21u highflow
so in other words if you're on the factory ecu stick to the factory r33 turbo. I'm sure the R34 turbo will run okay but it wont be perfect without a tune
yeah i am planning on getting a Nistune ecu as well.. can anyone recommended where to buy Nistune ecu or would you recommended Apexi Power FC and Boost controller ? thanx guys
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
