I've just recently purchased a 2002 S1 M35 Stagea from Japan.
It's about to be loaded onto a boat and I've got a whole bunch of photos.
I had some pretty specific requirements as it's going to be my daily driver.
I managed to land (I think) a fully-specced S1 M35 which is in really good condition with the exception of a small dent in the rear bumper.
I was aware of this before I purchased it.
It's pretty minor and doesn't actually bother me that much, however, I'm concerned that it may qualify as 'pre-existing damage' from an insurance perspective.
Just Car Insurance just rejected covering the car due to pre-existing damage stating that I have to get it fixed before they will insure it.
Can anyone provide advice on where I might be able to get this repaired in Brisbane?
Alternatively, is it worth speaking to the insurance companies (providing pictures) to try and get insurance with the minor damage as is?
I've attached a photo of the bumper.
Thanks.
Stagea Bumper
Edited by MayhemVC
https://www.sau.com.au/forums/topic/455353-m35-s1-rear-bumper-repair/
Pre existing damage? It's barely a crease... And you told them about it before hand anyway. I don't understand insurance companies, they would likely call that a write-off due to not being able to source the parts.
Any bumper repair place should be able to heat that up and smooth it out, depends if the insurance company is happy with that repair though, now they know about it.
I have a Blue rear bar here, will need a sand back and respray, but it may be cheaper than the repair quotes if shipping is cheap enough. Otherwise scour the wreckers for a silver one?
  • Like 1
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
