  • Replies 130
I've got a VG30 turbo for sale if your interested!! Ball bearing etc etc, basically same turbo as u have now, just slightly bigger compressor wheel so i'm lead to beleive!!! Bolts straight up though and i agree with everyone else get a BOV, even if its just a stocker one thats fed back!
The VG30DET turbo's from the Leopard or similiar have a larger exhaust a/r BUT have a slightly smaller compressor wheel than the RB25 terbs.
They are ball bearing and have a ceramic exhaust wheel.
They are worth around $400.
There is an older VG30DET turbo that is non-BB and has steel wheels.
They are slightly cheaper again.
You may be better off hunting for a second hand T3/4 from a jap wrecker. I've seen them for around 1k. I've seen RB25 turbo's from jap wreckers from $600-$800.
They can be found for $500 or so from those RB25 owners upgrading their turbo's. :)
Yep well i have the ball bearing VG30 one...Im looking to get around $300 for it, i bought it for my FJ20, but i've bought a manifold that i was told the turbo would fit onto and it didn't :) So i had to buy the turbo as well not that thats a big issue hehe :)
So which one do you have the BB or the non-BB?
I'm going to be running the stocker turbo on the RB30det for a little while.
I may grab the sucker if the other bloke doesn't and see how it goes on the 3ltr.
I've had one on the 2ltr and it was crap, 12psi by 4200rpm :)
an also yeah i will get a BOV.....probly HKS SSQV...so if ne1 has got 1 of them 2 suit R33 already..ie: cbf gettin adaptor made or buying 1 seperate...jus want 2 get it an bolt it on
also when i get a replacement turbo...does ne1 know wat i will have 2 do besides bolt it on...like will i need 2 strip the motor down an clean it all up???? thanx ppls help appreciated
Pm has been sent :mad:
my bro's friend talked 2 me on the fone an asked me 4 million q's an reakond it was a blown turbo seal..
Well that doesn't sound like the most reputable source now... does it?
Perhaps before spending your cash on a new turbo, you should get the problem professionally diagnosed?
I think you'll find your answer lies in the 3rd post in this thread. Everything points to a cracked ringland and a whole heap of blow-by. Take Buster's advice and get a leakdown test. It's cheap, and I think it'll save you about $300 or however much you're planning on buying a VG30 turbo for :)
k will chek out man,
thanx im alwayz after a second opinion....will try 2 get 1 done 2morrow......mate i have no idea wats rong with it..thats y came on here 4 sum advice.....so thank u every1..will let all know wat the prob is 2morrow if i can get cheked
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
