Hi guys i have opened a new work shop and im doing a lot of work on skylines if anyone has a problem drop past and say hi
the address is 1389 Camden Valley way Leppington
ph:96067699
Can do timming belts $175 + parts and great prices on other jobs as well
Good Luck Jason. I live in Port Macquarie, but my sis lives in Horningsea Park, just down tha road from ya, so I can come down when I need work done.
Cheers,
J-Flash :)
https://www.sau.com.au/forums/topic/45584-new-work-shop/#findComment-928725
  • 8 months later...
no offense but your comments before on the hicas thread make u look so arrogant personally i would never go to your shop if i lived in sydney
you make it sounds like u got so much experience because of the cars u had too
heh
no problem but i have done the job a number of times and if that is the way you feel good. :wassup:
https://www.sau.com.au/forums/topic/45584-new-work-shop/#findComment-1285065
heh
no offence? nice of you to dig up an 8 month old thread to hang sh1t on someone's business.
all class.
https://www.sau.com.au/forums/topic/45584-new-work-shop/#findComment-1287210
