Hi All,
New to SAU. Excuse my limited knowledge for future reference.
I recently purchased a N/A r33 S1.5 (s2 management) with intentions to go down the forced induction path.
I purchased a Rb25det s1 engine,loom and ecu. I installed the engine trouble free but had a few electrical bugs, using the s1 management I can not get injector or coil pulse. I've tried multiple CAS with no luck and have narrowed it down to no power to the Ecu.
I then tried using the N/A s2 ecu,loom and plenum with all n/a sensors.
(Of course changing coil packs,tps and afm)
The car started and idled fine but run like shit on boost.
I changed to a S2t ecu,fuel pump and adjustable FPR
The car run what I thought was perfect.
After a small drive I've found it runs VERY rich @ idle and VERY lean on boost >4000rpm roughly
It's like the Ecu is not recognising "boost"
So this is where I am at now:
S1.5 car
S2det Ecu (only 1 relay next to ecu)
S2 N/A loom
S2 N/A afm
S2 N/A plenum and sensors
Det injectiors
Adjustable FPR @ 30psi- I've noticed a lot of fluctuations in pressure- some days 10psi some days 35????
S2 coil packs
S2 Tps and TB
Walbro 225lph
Boost T @10psi
So to me I belive there are no ways the car can sense boost since I do not run a boost solenoid using n/a loom?
The car will get up and go ok but feels to have no torque. It's just all noise.
I come back off the track with a glowing turbo.
The car will idle insanely rich to the point where the plugs fowl after 2 mins of idle @800rpm
The car will run amazing and pull well sometimes but very moody on when.
Also wondering if it's my fuel pressure fluctuating?
Let me know any troubleshooting ideas anyway guys and girls!
Look forward to joining the SAU community.
Max.
https://www.sau.com.au/forums/topic/456099-rb25det-milkshake-motor-issues-help/
I came in here reading the word milkshake expecting you to have blown a headgasket or the oil cooler.
You are correct. There is no "boost sensor". The load sensor is the AFM. It helps to use the correct one for the ECU and engine type.
It sounds as lean as f**k too. That could be because you have the wrong AFM, or it could be because your fuel pump is not up to the task. You should not do this sort of crap without having some basic test gear hooked up. Fuel pressure gauge sounds like a good one.
  • Like 1
I meant milkshake as in a bunch of different parts in one car haha,
Ok so there is a difference between a DE and DET afm?
Yes it is lean above 4k, I have a narrowband as a rough reference, I know they are pretty basic but still gives an indication
Yes my fuel pressure gauge jumps over the shop a bit.
So are there any differences to engine operation between the N/A and DET loom?
Thanks for your reply mate :)
Okay you will need the Afm from the same car the ecu came from.
You also need to set base fuel pressure to 45 psi with the FPR unplugged from the vac/boost source
Ignore the narrowband gauge they're worse than useless
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
