A week ago I noticed my car started to misfire irregular at idle. Wasn't constant just a miss every few second. Also started missing under low rpm acceleration and was fine a 5000+ rpm. I changed out the old spark plugs with new ones and the car ran Amazing.... for about a week. The car has started showing the same symptoms as before. I just don't understand why the car ran so well after the installation of the new plugs only to start misfiring again a week later. Any advance is welcome.
Thank you
Perhaps your plugs have fouled due to running rich.
Seeing as you have given no info at all in the car I'm going to guess.
It is stock. Except for an exhaust and raised boost. And a different Bov. And you only recently Bought it. And not sure if it has a tuned ecu or anything. But it goes hard. And impresses your mates.
Okay more about the car.
I have had it for about 8 months now and this is the only misfire issue I have had with it. The misfire as stated before only occurs when the car is warmed up.
the car is relatively stock. Exhaust system with Test pipe. Air intake. Boost gauge and turbo timer.
as far as I know the car has not been tuned.
thanks
I'll pull them out this weekend. I don't think it's the maf. I cleaned it and when I unplugged it will the car was running the car stopped running. I noticed that the misfire only occurs at idle and from 1000rpm to around 2500rpm. I also noticed that at high rpm there is like a screaming noise coming from the engine bay. I don't know if the misfire and this are related or not.
Edited by shaneAS97
The handiest tools for these sorts of things is a consult connector and a logging program. Fluctuating timing, or fluctuating injector values would be a good giveaway of a problem. You'd also be able to see the o2 sensor value. But some misfires can be cryptic. Ive got an occasional misfire at low rpm. I have new plugs, coilpacks, stable timing and injector pulses.... but still an occasional fart at idle.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
