I have a trust t67 turbo that i was going to use on my car but i am now looking at possibly using a different turbo.
It will be fully rebuilt with new seals/bearings so be in top condition, rated at 550hp, has a 8cm^2 exhaust housing so it will not be laggy and still make good hp, perfect for a nice streetable rb25 or even the 3ltr or rb20 will not be too bad. has a polished comp cover. looking to sell for $1400
pic below, email [email protected] for more info or if you have any questions, i adlelaide but will ship
https://www.sau.com.au/forums/topic/45656-eoi-trust-t67-turbo/
