Morning all!
Yeah Trev, this is possibly the worst carton of Sapporo I've ever had :(
Didn't take any pics of the ribs sorry but they got the thumbs up from all in attendance, she even went back for extra sauce because it was apparently that good! :woot:
Kirin lager in Japan is probably in my top 3. Over here its terrible. They don't do stubbies so it's usually a good giveaway its Aussie beer rebadged
Asahi is mainly brewed locally as well.
I'm fairly sure the Asahi and Sapporo cans are fully imported though.
those 500ml odd shaped sapporo cans were good so probably legit. havent tried asahi cans here, but they arent my favourite beer anyway so i wouldnt normally buy them. they are pretty exxy over there compared to most others... i dont know what all the fuss is about
its gets advertised absolutely everywhere...
ive asked over there about it and told by a couple that it wasnt their regular beer but for special occasions or if guests were coming over then it was kind of the right thing to do
Hmmm... interesting.
I think out of the 3 (Sapporo, Asahi and Kirin) Sapporo is generally my favourite but obviously when brewed and flown in overnight from Ja-pan.
    • LOL, all of the CAI like Craig I just need to put a hole saw through my bumper Done and dusted, the car runs, which is nice, I'll take it for a spin when the weather clears up Just need to put the bumper back on for good
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
