looks the goods but im not going to melbourne for japanese beer...
japan trip?
I see no other option but a Japan trip.
I really should keep an eye out for a killer deal on flights
  • Like 1
i cant believe you havent been looking already... you seem to find all the good stuff
speaking of which, scoopon tacos got forgotten?
Still available, I might grab a deal for 4
https://www.scoopon.com.au/deals/68696/all-you-can-eat-tacos-extravaganza-in-south-freo#/
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
