Dunno how you leave the house without one, I need it within 5 minutes of waking up
I've been rying to become less dependant on it, I even only bought a small!
Edited by Hank Scorpio
Looks bling. Mine just has a switch with 3 settings, 1 for flowers, 1 for fruit, and 1 for meat. But good price for what it is. Can prob get one at good guys for $50 or so.... But I know how much you like online shopping ;)
