Yep, about to jump on the Jerky wagon!
The Cube is a cool car, basically the same engine and drivetrain as the Micra so parts and stuff are easy to get locally. They look funky, have lots of room and you can buy a bolt on supercharger kit! Perfect city daily.
  • Like 2
Brilliant , that's what I want bigger space inside and perfect for daily use , I have Honda Civic ( Sedan ) as my daily car now but not big enough for what i want to do with it. Thanks Lachy X [emoji509][emoji517][emoji508]
And bonus, it's not a Honda! :woot:
  • Like 2
Don't buy outdoor furnitures from segals [emoji90][emoji35] Cheap furnitures with bad customer service ! Paid for delivery but they refused to bring the goods inside the house , instead leave them all the big boxes outside the house for me to bring it in ? What am I paying the extra $80 for ??????? post-139458-14579294621784_thumb.jpg
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
