Settle down woman, how many coffees you had lol
Hahahahahaha none ! I don't drink coffee or tea [emoji41]
Been up and on site since 4 am , then move to different site here I am at the gym sipping my No X-Plode ( energy booster hahahahaha )
Skyline needs rears...
Thoughts? In 17's. Thinking of trying ku31
225/45R17 or 255/40R17?
Toyo Proxes R1R or Advan Neova AD08 are both amazing (Got R1Rs on the Hippie Killer)
https://tyrebuy.com/store/225-45-17/michelin/pilot-sport-3/088461
https://tyrebuy.com/store/225-45-17/pirelli/p-zero-rosso-mo/1504100
Both of those would be pretty good though.
Go 225/45R17, better size on the R33 IMO (235 is a bit taller than the factory tyre, 225 is pretty much spot on). But you can use the 235s if you want of course, I'm not gonna' stop you! :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
