Trev [emoji28] oops sorry ! Painting are not cheap, normal price from 2k-5 it depends [emoji28] but if you can do it and have all the time in the world why not ? I've got lucky when one of my staff offering cheap price [emoji23][emoji23].
Fur babies you meant hahahahaha , love of my life [emoji171] it's strange when I need to sleep in they seem t understand that , they won't get up until I'm up [emoji23]
Yea don't like double demerits :(
I'd pay 1k for painting but prob not more. Just do it myself.
I'd love a sleep in...
Good morning :)
  • Like 1
Hey guys have a friend who may have a car (rx7) with rollcage but no motor or box and rollcage is all approved and at spec level which we can work out a deal if you guys are intetested at
What's he want for it?
I'm not able to commit to it yet... I need to sell a house before I can spend any monies
  • Like 1
It's almost 5 am Trev ! Is it feeding ninjas time now ? [emoji28] Hahahaha -
Morning Trev and All
Trev don't work too hard , take it easy and chill it's Holiday
Edited by ElleAli76
I was on the road before 5am
No holidays for me :(
  • Like 1
Morning all, geez Trev your going off in here lately its good to see
Thanks for noticing
Your good to see ;)
Sorry for holding you up the other day. Didn't realise people were waiting for ya.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
