I can't eat cod ,
or mackerel fish :( skin reactions :(
Loved trouts if you marinate em with bit of curry powder , salt and a bit of chili powder and fry it - try it it's so good :)
Edited by ElleAli76
Name?
Beer ?/10
Food ?/10
Bush Shack?
Beer 6/10
Food (There kitchen was not open, they had a food truck there) 6.5/10
Would not go back.
If I was to go down south again without annoying little kids there would have been many more breweries lol!
  • Like 2
Bush Shack?
Beer 6/10
Would not go back.
I've never been there - I meant busselton . Any nice hotel ? Country town ? And is it safe ? [emoji87]
Edited by ElleAli76
Stayed in a holiday home.
I didn't get stabbed or anything... but I do live in the 6061, I do the stabbing ;)
  • Like 1
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
