Healthy much! Famous coffee shop? Mmm I don't like franchise coffee shops haha, but good investment though
Oh are you looking for franchise business for investments ? Gym ! Fitness anything with healthy lifestyle , or run your own business - Accounting !
Lol I am in accounting and financial planning :) not owning it yet though. Fitness - requires quite a big capital and you'll need a pt or two at least. I gym but I'm not that crazy so won't be able to...
F&b I guess is a tad easier for me since I worked in the industry before kinda haha
  • Like 1
Ok fair enough , why didn't you set up your own accounting and financial planing services - it makes sense to run business with something that you're familiar with ?
F&B can be bit risky I won't go there [emoji6]
Morning all !
Morning all !
I don't have enough of a client base / network to do it as yet.
F&B - yea definitely risky, can agree with you there. Not 100% going into it just yet. Just looking around what's in the market etc.
  • Like 1
Morning~~ Trev caught any salmons?
Just got home. Yeah I got 5 salmon and few bream, between 10 of us we got about 35 salmon and 30-40 tailor, mulloway, herring and bream.
Unfortunately the bream kept taking the bait really quick so the salmon didn't have much time to get it. Pretty good weather too.
Time to unpack :(
  • Like 1
Mate have faith , promoting your business on social media , get few awesome feedback for all the job you've done before , advertise your business on gumtree or service seeking for you to get more clients [emoji28] simple as that [emoji23]
Run your business from home, or clients premises with the software that you're familiar with and target all the small business owner [emoji6][emoji108]
  • Like 2
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
