So, Upon starting the car this morning (to see if the battery held its charge, which it didnt, the coolant leak returned. So Im thinking cracked/loose hose possibly? the leak only occurs while the car is running.
Has the battery been flat for a while? If so its a bin job
I don't have the right tools for that at the moment (i am very unprepared )
But, Headlights are Restored, and im pretty happy with myself!, I also got all the dust and grime out of the inside, prepping for the big clean.
Pics: (Top three are After) https://imgur.com/a/m3FfR
it's so sunny that it's hard to tell, but they are more than twice and clear.
oh, and yeah, I know the battery is a bin job. Alternator is cranking fine, my little diagnostic tool tells me the battery, it's discharging at a pretty fast rate, so Once i'm done cleaning her up, I'll fix this coolant problem and get a new battery.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
