1 hour ago, turboedsloth said:
Just worn out already for some reason. Doesnt look to be many aftermarket parts available so it will be a tighter std build.
If your board is the problem in your trans, they are fixable. Navaras experience the thumping problem and it breaks a join inside it, quick solder usually fixes it
Corey, will PM you in abit.
Long weekend was ok, still sick but did quite a bit considering. Finally cleaned the car as well...looks great now that the bumper and lip are fixed :D
Yep that's a daily occourance
Even just this morning the missus called me a teenager for still pitching a tent every morning when I get up [emoji6]
The daily struggles of being a man that women will never understand
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
