Issue I had with adoption agencies is that I never had a pet before and so they weren't too keen on giving me one.
HRWA are not like that, they just want to ensure you know what you are getting into, Huskys are a unique breed and are extremely active
Malamutes are just huskies on steroids.  all my animals are sleeping because they live happy relaxing lifestyles. my dog gets two 8km walks a day.
Oh, and yeah, adopt one. there's so many out there.
Edited by Manne
  • Like 1
Yea ok I'll have a look. House doesn't have an alfresco area. Ideally I'm hoping to get that up at least for work out door shade area for the dog.
Have a chat with Anne, as long as you know what your getting into you will be fine, they charge $400 for costs of desexing, microchips and worming etc
http://www.huskyrescue.com.au
Tell her I sent you 0413 770 092
  • Like 1
I don't have a very large house, in fact it is quite small. To make up for this, I take my dog for long walks and play with him at the park, which is perfectly fine. We'll play tug of war in the yard and sometimes we wrestle, he's 55kg...decent opponent.
  • Like 1
No wonder your knees are shot 16km per day plus walking around at work [emoji15][emoji15]
  • Like 1
35 minutes ago, shoey85 said:
No wonder your knees are shot 16km per day plus walking around at work emoji15.pngemoji15.png
So about that, I have some sort of Chondral Fissuring of both knees. Essentially, the Cartilage for both knees has deep cracks and fissures through it, some of it has also started peeling off of the bone, and there a small, loose bits of cartilage floating around the knee too.
Theres no surgical options, supposedly (Rheumatologist tells me that, so does my GP and Physio), so the best Cure is to Grind back the Cartilage with low-impact leg exercises.
I had to buy a particular Exercise bike, that has a heavy flywheel (7kg), set the resistance up, so it's like pushing a weight, a slowly do that for 30 minutes a day. This not only builds muscle, but grinds back all my broken cartilage, and hopefully creates a new groove for my knee caps to sit in. Unfortunately it's a long, slow, painful process, slowly improving every week.
Option B is to take Anti inflammatory pills for the rest of my life, with monthly (expensive) Steroid Injections and fillers (with the risk of infection from each one).
Fux man that's really not good, hope
You do get better sooner rather than later!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
