Was good to meet up some of you tonight , drive safe Trev , long way for you , Thank you for organizing the meet up Mark !
Great foods [emoji39]
Was a nice drive home. Some tunes and the road mostly to myself. Home just after 11
  • Like 3
Stopped at safety bay servo, when I was reversing out to leave, this guy comes running through the garden straight at me forcing me to stop.
Wasn't sure if I was about to get robbed or told to do a skid, he stops next to my window and says he likes the car, he really really likes the car, then I saw there was a car meet in the back carpark.
I thought he deserved to hear limiter up the On ramp :)
  • Like 4
Salute !
Hey all, buggered today, ride finished at 4am [emoji42][emoji42][emoji42]
https://www.strava.com/activities/855241424/shareable_images/map_based?hl=en-US&v=1486241648
Bloody hell ! 71k ! Bet you're knackered- sleep in and rest well then ? It's Sunday anyway hahahaha
  • Like 1
@pol1on1 Haha thanks, In need of a new camera too as this one is starting to get a bit fuzzed, yeah I had a look around but never found it, Ill call the tavern. Thanks anyway was fun while I was there, would be keen to come to any future ones.
Yes will tag you in future events.
As for camera sony do a full frame mirrorless body now. [emoji6]
Yep def tip my hat@pol1on1 was a well organized event thank you for doing it.
Cheers mate was no problem to do it.
I learned alot and will improve on next.
But thanks for everyone that came coz without it wouldn't be.
[emoji39]
  • Like 1
