Was good to meet up some of you tonight , drive safe Trev , long way for you , Thank you for organizing the meet up Mark !
Great foods [emoji39]
Was a nice drive home. Some tunes and the road mostly to myself. Home just after 11
  • Like 3
Stopped at safety bay servo, when I was reversing out to leave, this guy comes running through the garden straight at me forcing me to stop.
Wasn't sure if I was about to get robbed or told to do a skid, he stops next to my window and says he likes the car, he really really likes the car, then I saw there was a car meet in the back carpark.
I thought he deserved to hear limiter up the On ramp :)
  • Like 4
Salute !
Hey all, buggered today, ride finished at 4am [emoji42][emoji42][emoji42]
https://www.strava.com/activities/855241424/shareable_images/map_based?hl=en-US&v=1486241648
Bloody hell ! 71k ! Bet you're knackered- sleep in and rest well then ? It's Sunday anyway hahahaha
  • Like 1
@pol1on1 Haha thanks, In need of a new camera too as this one is starting to get a bit fuzzed, yeah I had a look around but never found it, Ill call the tavern. Thanks anyway was fun while I was there, would be keen to come to any future ones.
Yes will tag you in future events.
As for camera sony do a full frame mirrorless body now. [emoji6]
Yep def tip my hat@pol1on1 was a well organized event thank you for doing it.
Cheers mate was no problem to do it.
I learned alot and will improve on next.
But thanks for everyone that came coz without it wouldn't be.
[emoji39]
  • Like 1
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
