Yelp that would sound right new lip new bumper color match n paint plus fitment and alignment. About 2.7k later would be cheaper to pay the excess.
Or.
Say it was parked on the private property driveway and kids smashed a gokart into it. You ran out could not catch em as they speed off. Use that if you wana protect ya NCB and excess. Hehe. [emoji38]
  • Like 1
