Having some terrible luck with things breaking. In the past 10 days,
had garage roller door fall down. Just fell down again this weekend.
Drawbar on the boat trailer snapped (kinda my fault)
Bobcat starter motor failed
Drivers window jammed on my ute and a heap of oil leaks have started.
And the worst is the solar hot water system has burst and dropped all the water on the ground. Just had to shower at the neighbours :(
And the worst is the solar hot water system has burst and dropped all the water on the ground. Just had to shower at the neighbours default_sad.png
f*knell mate did you build on a sacred site!!
  • Like 1
    • No requirement for JDM vehicles,  which the 33 is, maroney label only needed in the US market for new cars I believe (Federal law stuff) Google knows all
    • Hopefully you can just unbolt them, thank them for their service, then bin them and not replace them Apparently the sensors like to set them off with only minor impacts at low speed It looks like they do a delete kit for some of these, but, it is costly
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
