Hey guys we also arrived here yestetday any recommendations on what to go see?
Always a good idea to go the the towns info center and stock up on brochures. Thay have a table note pad thing with maps on it. Its really a good map.
Ill be planning on the drags but if things don't go well than sight seeing it is.
My next thing to do is marron farm.
