42 minutes ago, ElleAli76 said:
This is Bloody good stuff ! Colin You should try it !
we go through one every couple weeks.
Japanese ricer is tastier and i dont need it but here ours is a bit bland and boring
  • Like 1
I'm sure they sprinkled this in my ramen or any Japanese foods that I had in Japan , I saw this in Asian groceries today , so I bought it and this is my first trial, had it with mashed potatoes, tuna steak , mushrooms and Wasabi Cheese lol [emoji23] IMG_5815.JPG
Surprisingly it taste so good [emoji39]
18 minutes ago, t_revz said:
You didn't like it?
Oh nah Motul is good, been using 300V for a few year. I just find that it turns black quite fast. I am changing as KYP recently become Moty's distributor in Australia. So I will be changing over to test it out. From what I have heard and read it's very good oil. Apparently in Japan when the cars at the endurance race used it and when they took the engine apart after the race for a rebuilt, those engines using Moty's didn't have scratches to the block or pistons etc. But as usual, I take reports with a grain of salt...what better way to just try it out lol.
  • Like 2
so I rung my insurance company, because now it's considered "theft"...the only problem is they want $200 MORE than what O'Briens are charging me to do it privately and I'd lose my no claim bonus...
Why the hell am I paying for insurance?
Have done on motorcycle only why's that ?
Just use windex [emoji23]
It's insurance until you call them up and realise it was only a assurance for your piece of mind. Then everything else will cost extra. Oh sorry we sold you $1000 bills worth of lies. (sorry)
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
