42 minutes ago, ElleAli76 said:
This is Bloody good stuff ! Colin You should try it !
we go through one every couple weeks.
Japanese ricer is tastier and i dont need it but here ours is a bit bland and boring
  • Like 1
I'm sure they sprinkled this in my ramen or any Japanese foods that I had in Japan , I saw this in Asian groceries today , so I bought it and this is my first trial, had it with mashed potatoes, tuna steak , mushrooms and Wasabi Cheese lol [emoji23] IMG_5815.JPG
Surprisingly it taste so good [emoji39]
18 minutes ago, t_revz said:
You didn't like it?
Oh nah Motul is good, been using 300V for a few year. I just find that it turns black quite fast. I am changing as KYP recently become Moty's distributor in Australia. So I will be changing over to test it out. From what I have heard and read it's very good oil. Apparently in Japan when the cars at the endurance race used it and when they took the engine apart after the race for a rebuilt, those engines using Moty's didn't have scratches to the block or pistons etc. But as usual, I take reports with a grain of salt...what better way to just try it out lol.
  • Like 2
so I rung my insurance company, because now it's considered "theft"...the only problem is they want $200 MORE than what O'Briens are charging me to do it privately and I'd lose my no claim bonus...
Why the hell am I paying for insurance?
Have done on motorcycle only why's that ?
Just use windex [emoji23]
It's insurance until you call them up and realise it was only a assurance for your piece of mind. Then everything else will cost extra. Oh sorry we sold you $1000 bills worth of lies. (sorry)
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
