Enjoy boys ! My Car is in the garage tucked in under blanket :) prob won't be driving until next meet up or I don't know :)
Was thinking to hire the barbegello race track on my birthday ( private invite ) will update you boys soon if that happen
  • Like 2
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
