evening all,
having so much fun lately modifying the water/meth setup in my ute and fixing the crankcase breathing issues.
1- first hill on the way to work, if i hit it at 100 in 5th i would slow to 70 in 4th. now im able  to do 90 in 5th
2- next hill i used to hit at 100 and slow to 80 in 5th. now i can accelerate to 120 in 5th
3- final big hill i used to hit at 110 and fall to 72 in 4th. now i can maintain 100 in 5th or 120 in 4th
still so much more refining and testing to do. tomorrow i have better pyros hooked up for more accurate temp readings.
Show us your ute!
On 02/04/2017 at 8:07 PM, t_revz said:
im gonna take a stab in the dark and say about 144km, give or take 300metres
300m sounds good to me. Flat chat on a BMX! Puffing and panting like a dog in a hot car!
8 hours ago, z00key said:
Hey guys in a week and a half the fate if the furious is out (fast n furious part 99) comes out (12th i think) is anyone keen for a meet eat and movie night?
have fun!!
  • Like 2
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
