I have to go to the pool at least 3 times a week for the back. I normally do excersize and stretches in the hot hydro pool then go to the 25m pool for walking and swimming laps. I've got dodgy knees too and if I walk too much in the pool they ache real bad but it's only Austio arthritis. I was in and out of physiotherapy for years and just pissed it all off did a load of research and found a balance that works good for me. What is the main problem with the knees?
A few of my mates I played footy with had Osgood/slaters and it finished them. After over 200 games of footy I wish I'd never played but I loved it alot. Football is my family's religion! But I've lost interest over the last few years. Not as hardcore as t-revs with his West coast Eagles engine bay!
Yeah not bad. How was the drive home car still good and did ya hav3le a grin going home thinking I got a 12 sec car
Hey Dean I found a awesomeness little R35 on Gumtree for the boy. Would post the link if I knew how. Have you got any of the r/c's up and running?
  • Like 1
1 hour ago, Beyond Blue R33 said:
DSC_0348.JPGDSC_0347.JPGthe earlier time was the faster. Dropped it to 30 psi all round today. Do you think the duramax 75-90 is the right oil for the diff? It was juddering bad when I changed it then came good with the l.s.d. Paste and figure of 8's? The tein basics have only height adjustment and the ride is hard as since I lifted I't?
Track temp definatly didnt help, colder it gets the less sticky it becomes and less traction u get. Same principle when its too hot.
Diff oil sounds about right, was the old oil burnt? Id day that the shock from spinning the tyres to it gripping proberly caused it to tighten up through heat. New oil and a some maneuvering always helps.
Ur shocks are gonna have more travel due to increased hight, more fluid to move bk and forth within its stroke which will make it feel harder
  • Like 1
Hmm makes sense, that's what I was thinking too much extension and not enough compression in the shocks which would coincide with the longer travel and higher spring rate. When you gradually build up the boost and launch it sweet on the street is the only time you notice it. The old diff oil was clean as. I was also thinking due to getting cold between runs that it was at its minimum viscosity but the thinner the oil it should make its way into clutch packs better?
I watched footy in high school and early twenties. Now I despise it. I'd rather watch netball or lawn bowls
  • Like 2
i watched WM on youtube. there is 26 x 22minute episodes plus there is a movie
i enjoyed the series more than i expected. initial D was better but its still very good. the movie isnt bad from memory either
  • Like 1
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
