I'm still 99% coming to see ya for a dishwasher and look at phones this week. I can take a look if you have it at work
Maybe use a wider bit of cardboard mark off where the wheels are then stick it over the top of the engine bay for reference. Just a thought? Such a pain up on axle stands. In and out with lights. Hate not having a hoist at work anymore.
FYP
i have the same problem
I sussed out if there was any play in the tail shaft / axles on Sunday and it seemed pretty good. Checked upper/lower rear and subframe bushes and was all in reasonably Good condition. I lowered the rear tyrepressure from 34 to 30 with 32 in the front for a similar foot print. Drove better but there is obviously a underlying issue?
Who else is going to the drags Wednesday?
Am interested in going for another run but will have to check if I can take the car to work. Had to go home to beechboro last week load tools in the xr8 and rush down there through poxy as traffic?
Wife said do I ever have to do that again? It was boring. She only liked the lumpy as 10sec Monaco. Total bogan.
im hanging to go get some squid,
hopefully the weather is nicer next week
Hey honey I caught a heap of squid and they left big ink marks out of the shed then onto the road outside our place. Damn those squids.
  • Like 2
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
