Out of interest where would you put the auto flex? Assuming you're doing it yourself not looking at pics or posts? Before or after the cat? Would be keen to see all the pics of your build? Must be a insane machine? A veritable titan?
I have photos that show all of the exhaust except the front pipe where the flex joint was.
1 hour ago, TiTAN said:
She wasn't pretty. But she got the job done.
4" dump, 3.5" front with flex pipe, 3.5" cat with 5" body, 3.5" to the middle muffler, 3.75" to the rear muffler and a 4" tip.
25/30 with a gt3582, 394kw @ 26 psi and 90db @ 3500.
This is the exact setup im going for.... ? atleast i know what to expect ?
2 minutes ago, TiTAN said:
Expect that the 38mm height difference in the block is far more annoying than you think it's going to be.
I have a grinder, hammer, welder and a soldering iron. We can make 38mm work lol
Stirred in natural yoghurt before serving:-) yum
Jack wanted to make a Korma chicken curry today? I'll show you how mate marinate the chicken. Set it aside. Get the oil hot close to bubbling then ad the spices stir and only just spoon in a few pieces! All the chicken dropped out the bowl into the piping hot oil an whalla!DSC_0149.JPGDSC_0148.JPG
Jack wanted to make a Korma chicken curry today? I'll show you how mate marinate the chicken. Set it aside. Get the oil hot close to bubbling then ad the spices stir and only just spoon in a few pieces! All the chicken dropped out the bowl into the piping hot oil an whalla!DSC_0149.JPG.1e949b087f3dda053e6ca7f4cdb3b4f0.JPGDSC_0148.JPG.68d26367b6202780e3b0c0dde2c346c1.JPG
This is my hand, splashed the piping hot oil onto it. Chicken Korma with blistering skin! Yum!
Frankensteins monster, bolt of lightning to fire up that nasty s.o.b.!
Exhaust won't fit, intercooler piping won't fit, clearance to the clutch master cylinder is quite tight, cam belt covers need to be modded.
Wiring isnt an issue from memory, it's just anything that used to bolt onto the head or between the head and block are now 38mm too low/short/out of place.
Sounds like a giant ill fitting jigsaw. Im sure il gwt it worked out with a lot of swearing and cursing
OUCH
Blistered up yet?
OUCH
Blistered up yet?
Amazingly looks pretty good today. Did 1 hour of cold water on off till the heat disappeared. Wrapped in sterile cloth and glad wrap. Nurse said just put antiseptic on for 5 minutes then pat clean keep re laying dressing.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
