That's me if I stop drinking mid arvo.
Drink down and out like a light
Back on the road again tonight. Yey. New cat silicone hoses gaskets clamps intercooler flush and swaged modified piping work viscous coupling and fan. Ran sweet at 14psi, full test at 18 tomorrow?
Morning boys , off to Malaysia [emoji1157] Penang Island today - you boys behave and be good ok , I'll see you all soon , foods party at my place somewhere in July , hope you all can come x
  • Like 1
7 hours ago, ElleAli76 said:
Morning boys , off to Malaysia emoji1157.png Penang Island today - you boys behave and be good ok , I'll see you all soon , foods party at my place somewhere in July , hope you all can come x
Yes mum ?
  • Like 1
