If he can be trusted with this:
My shit box won't be an issue! ?[emoji23][emoji6]
I thought the same thing when I took my car to 1st repairer (did/specialised in mustangs and restorations) ended up doing such a botched job, all i can say is some who specialises in imports. Anyway if marc can vouch for em should be ok
Active Red would be more appropriate
Drivers side speaker box sorted.DSC_0250.JPGHey Dean. Was just wondering. Cadence amp does 2x100w @ 4 ohm. Or 2x150w @ 2ohm both in L+R stereo. Speakers are 200w rms. 2x10" dual voice coil 2 off. Should I hook them up at 2 ohm or 4 ohm?. Sealed boxes.
Drivers side speaker box sorted.DSC_0250.JPG.d68a8334c3000d8e1e97f83082671afd.JPGHey Dean. Was just wondering. Cadence amp does 2x100w @ 4 ohm. Or 2x150w @ 2ohm both in L+R stereo. Speakers are 200w rms. 2x10" dual voice coil 2 off. Should I hook them up at 2 ohm or 4 ohm?. Sealed boxes.
Individual L+R off amp not bridged?
Ud wanna run them over powered wouldnt ya? If ur speakers are 200wrms ul need a amp of atleast 200wrms to power it properly.
  • Like 1
So 2ohm at 150w? Not going Going to buy a new amp.
I do know what you mean though. Amps are mounted and rubber insulated got full size 16x205x55 spare in with false floor. Speakers are going left and right hand side of boot. DSC_0251.JPGDSC_0252.JPG
4 ohm will go all day. 2 ohm could hit thermal cut out if loud for long.
I'd start at 2 ohm and switch to 4 if it doesn't work well
  • Like 1
What resistance are the subs?
4 ohm?
4 ohm single voice coil. 2 ohm dual voice Coil. Easy to change out. Might start at single 4ohm for less load on the amp at 100w If not happy change to double 2ohm 150w from the amp. Rockford fosgate prime r/2 10" shallow dual 4ohm subwoofer. Sealed boxes will put more load on the amp so maybe start at 4ohm then switch up to 2ohm. Only really crank rock and metal when the boy is in the car. I'm quite happy with the RB soundtrack except for cruising at 3000rpm at 120kph. Just weekend jobbing for fun really to play with my new nail/staple gun. Plus full size spare and L+R separation. [emoji4]
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
