There isnt a whole lot of info on rb30dets in my desired relms of use. Most rb30dets area drag monsters...
Hmm suppose it's the difference between a punchy quicker less laggy spool or a wait for a bit and get the the the holly f##k on it scary spool. Response vs shear power balance. Loads of rb's you see with bigger turbo's tend not to be able to get off the line or blow up boxes half shafts and diffs. I'd say with the bigger turbo you would need a mental clutch and longer ratio to get the power happening or it would just snap stuff and light up the tyres permanently. Which is also fun:-)
6 minutes ago, TiTAN said:
High flows have been tried on an rb30 years ago. It was a cheap build basically stock Na bottom end with the 25 head and it came on like a light switch but come 5000 it hit a wall, by 5500 it had dropped about 100kw from memory.
This is no gd... mine will be a forged bottem end so looking to lean on it some ?
Being a 3ltr it will have more torque anyhow so perhaps response is the way to go? Don't forget I'm only a sheet metal worker who has never blown up a Cleavo Windsor c4 top loader or 9".[emoji4]
Gtx3582r with an 50mm external gate is what i was also thinking. Either way i think external gates gonna be better
I had a pre gtx series 35r with 0.82 rear. If you tweaked the waste gate setup you could have 20psi at 3500. Traction was non existent below 100km/h, for Street use it was too laggy to be quick and too fast to be usable without potential jail time. You would start seeing positive boost (a few psi) at 2500 with a bit of load.
Guilt-toy had a similar setup and should be documented fairly well on sau.
This is my dyno sheet, 26 psi and the dip at 145 was spark breaking down, done on a 33c day.
13 minutes ago, Beyond Blue R33 said:
Being a 3ltr it will have more torque anyhow so perhaps response is the way to go? Don't forget I'm only a sheet metal worker who has never blown up a Cleavo Windsor c4 top loader or 9".emoji4.png
I hear u can get cheap pipe? Gonna need some mikd steel and aluminium to make some pipe work. Proberly not till later in the year tho
  • Like 1
Hell yeah, that looks right up my street. I wont be using it much on the street, mabe once a week at this stage. Il proberly get hooked at drive it all tje time lol
thats a run out at an airport, i am not even an amateur film maker obviously as its hard to even read any of the gauges. had spark breaking down at 160 then it clears up and keeps going, trapped at 242km/h at the 800m mark.
  • Like 1
Sounds gd ?
16 minutes ago, TiTAN said:
That's mainly to give you an idea just how quickly 400kw puts on speed.
If it's going to be a track toy, you are going to need some serious brakes to deal with stopping it. Upgraded pads and rotors won't cut it.
350 all round. Alpha omega brembo upgrade. Dba discs and bendix pabs. With all my cars its always been suspension, tyres, brakes then power.
Posted some pics of the boot fit out. What do you think of it?
Looks good mate, should sound good too.
A lot of bass is lost through the back seat of our skylines due to the steel plate etc but will still be plenty of punch no doubt.
Is it all hooked up and running now?
  • Like 1
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
