20 minutes ago, TiTAN said:
Lachy must have finally hit his rebellious teen phase.
We can only hope it doesn't take a few years to pass.
Shut up! I do what I want!
  • Like 1
came out in 1991 when I was 16. Ouch:-(
Jack has been listening to avenged sevenfold. He freaked when I knew all the words. The dualists, maiden 84. Walk, pantera 92. Paranoid, Sabbath 70. Yep there covers mate and damn fine ones!
  • Like 1
Morning All ! Last day in penang [emoji4] my work in penang finally done [emoji736] [emoji7].....:so is the car cruise & eat happening soon ?
Should get the 34 back this week ?? as soon as I do will let you guys know!
  • Like 1
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
