32 minutes ago, ElleAli76 said:
Thanks!
I also need to sort out some house cleaning with you while I'm away on holidays, I'll give you a call later :)
  • Like 1
Just now, Manne said:
Everything is fine as far as I know, his baby is due in 2 weeks? so i'm assuming baby prepping is eating up all of his time.
2 weeks? That doesn't leave him much time to push his missuz down the stairs... ¯\_(ツ)_/¯
  • Like 1
[mention=143902]shoey85[/mention] [mention=139458]ElleAli76[/mention]
M
Thanks for the info Manne, would
Like visit him if he's around
  • Like 1
Thanks!
I also need to sort out some house cleaning with you while I'm away on holidays, I'll give you a call later [emoji4]
Anything for You darling ! Just Give me a Call , Also where You going ?
Just now, ElleAli76 said:
US ? !!!!! oh Im So jelly ! You old men - go and have fun xx
Thanks, we will! If you need me to grab anything while I'm over there just let me know :)
  • Like 1
Thanks, we will! If you need me to grab anything while I'm over there just let me know [emoji4]
Only if You go New york :) Is Errin going with You ?
Anyway Im off to guthrie Street to See Phil, I should made it on time [emoji121]️
  • Like 1
Anyway Im off to guthrie Street to See Phil, I should made it on time emoji121.png
LA and Vegas with Keith from work.
  • Like 2
1 minute ago, shoey85 said:
Remember what happens in Vegas stays in Vegas except for AIDS that shit will come home with you!
Can't catch it twice m8 ;)
  • Like 2
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
