I’m using Tapatalk app it works better than the SAU app, notifications actually work!
Yeah I've been down on and off since Friday. Missed all the purple pics and the nurse trevs folio;-)
  • Like 1
Thanks everyone, born monday evening 6.50. (Was due 1 November) so arrived early. 3.1kg so far all good and well.
Go team Dean, a beautiful baby boy. Must look like the wife oi, top effort for two pumps and a squirt. Wish my dad had a 34. You are a awesome dad already. Baby seat in the back with the boost controller. Mashing the scramble button when you're not looking:-)
That's why he has a 4door ;)
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
