Who’s up for a SAUWA trip to Bunbury to see old boy[mention=24655]t_revz[/mention] have a meal hang out for the day then head back?
Also[mention=24655]t_revz[/mention] when’s a good date?
Lets do it ! I should have my car back by then [emoji23] just drop the car at Phil’s
  • Like 3
On 10/22/2017 at 9:15 AM, Stinky Rooster said:
It was pretty sweet to put some faces to names yesty.
Also, I think ALL youse guys should give yourselves a massive slap on the back for the effort in getting this club back up and running.
Damn near bought a tear to an old mans eye seeing all the rice burners at city west. All we needed would be a couple of methed up SilWA morons running into each other at the entrance and it would have been just like old times </3
Sorry I missed you on the weekend :(
Morning all!
I'll have to organise another meet for when I get back from the States.
Also, Albany dinner for RaceWars (if anyone else is going) is totally going to be here -
http://www.hybla.com.au/
  • Like 2
Also@t_revz when’s a good date?
Always! Bunbury rocks my fkn socks.
  • Like 2
me too :(
Just now, shoey85 said:
Is it really Buny or is it Trev?
Sif not mention The Red Bearded Lurker.
Actually, where is the big huggable bear of a bloke?  Let me guess - working too many hours?
21 minutes ago, Stinky Rooster said:
me too :(
I'll be back in Perth on Wednesday the 8th but not back to work until Monday the 13th. Will you be working? Friday beers perhaps?
1 minute ago, Stinky Rooster said:
Ken oath. Hit me up when you are back.
If you are looking to get Hank out and about we should do the doggy playdate thing again soon too
For sure, they got along really well!
Perhaps I'll grab some brews and some chicken wings and we'll fire up the weber?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
