12 hours ago, shoey85 said:
Hey mate it was poxy hardly worth the drive down tbh, other than that the weekend was good, how was yours?
If i hadnt been busy with Owens appointments i would have gone for a look, mostly to see the caravan accessory stuff though.
Saturday i had heaps of dad duties, Sunday and today i trained the missus to be my T/A at building retaining walls. We built a 25M long curved wall from the driveway to the shed and didn't have a single argument haha
  • Like 2
Who’s up for a SAUWA trip to Bunbury to see old boy[mention=24655]t_revz[/mention] have a meal hang out for the day then head back?
Also@t_revz when’s a good date?
every 2nd weekend. ive just had this one off
3 hours ago, Beyond Blue R33 said:
10 hours ago, Hank Scorpio said:
Trev and Corey equally. It's the red hair that really boils my potatoes.
How many rangas are on this forum? :-o
not enough :banana:
  • Like 1
Wtf? Surely she knew better.
2 hours ago, Beyond Blue R33 said:
2 hours ago, R33kizza said:
Evo powered family mover!!!
Flat knacker squid run down the mountain pass. Not a square of tofu in sight;-)
mother asleep in the backseat?
she knows nothing about building and usually asking for help starts WW3
  • Like 2
Did u get her in a gd mood first? ? Il do you a favour, you do me a favour... nudge nudge wink wink ?
1 minute ago, Beyond Blue R33 said:
D.I.Y....... Now. Show us your wall.
ill take a pic in the morning if its bright enough, otherwise after work
If you didn’t make it then don’t be upset it was pathetic we went around the whole thing in 33mins!!
The big one is in Perth in November if your around that weekend?
  • Like 1
We are married... it doesnt work like that anymore haha
she just wants it done so we can put lawn down... plus all them monies saved $$
ahh ill be working that weekend :(
  • Like 1
Im married, my wife knows its the best way of getting me to do shit, specially shit i hate doing lol
7 minutes ago, R33kizza said:
Tied up in the boot, too much talk of ur raising ur kids wrong ???
haha was actually referring to the kid in Inital D s6 who learned to drift while his mum slept in the backseat haha
  • Like 1
2 minutes ago, shoey85 said:
If you didn’t make it then don’t be upset it was pathetic the whole thing was 3inches
The big one is in my pants if your around at the weekend?
Pardon?
  • Like 2
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
