9 hours ago, ElleAli76 said:
I havent Corey , But definately will look up for one and Also the other options is to wait for Lochy :)
Is it wise to use a second hand bushes?
No i would not advise it. You don't know how it has been treated before, if it has been affected by chemicals etc.
  • Like 1
8 hours ago, TiTAN said:
If it was a porsche, green brakes indicate it's a hybrid. Red has regular iron disks and yellow for carbon ceramic.
That's interesting. Mine is kind of a hybrid, 26, rwd, PPG, sedan etc etc
I havent Corey , But definately will look up for one and Also the other options is to wait for Lochy [emoji4]
High performance new Nissan gt-r. Keep it that way.
  • Like 1
Your gonna pull all the boys with them! I reckon Hanky’s gonna get wet for them [emoji6]
???? it’s good colour huh !
Can’t wait to see her with the new exhaust ! Hurry up galvesport!
  • Like 2
Fairly bright colour. My brembo stickers came in today also, waiting on the painter to have spare time to get all my bits done
It’s called hot pink and it’s a lil bit bright [emoji28]
Oh well [emoji28]
Surprisingly the calipers took a bit longer than the wheels !
Now how long would it take to have the exhaust fitted ?
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
