I’ve got radio earmuffs that I wear on the bobcat. Last week I heard a weird noise and thought the radio wasn’t tuned in properly. I took them off a minute later and realized there was a spider caught in the seal. Scared the bloody crap outta me [emoji887] haha
Haha, building a Web in you're ear hole minding it's own business.
On a more serious note lol, stick it gear and try and push it. If it moves u kniw its clutch for sure. Chances are its a dead slave or master
Slave cylinder over stepped the fork and knocked it of the pivot ball. Cause master cylinder. Clutch looks new no damage. Yeay. Turboedsloth and kizza correct. Show us your forum! ;-)
3 hours ago, Beyond Blue R33 said:
On 01/11/2017 at 10:03 PM, R33kizza said:
Iv got 2 spare rb blocks..... lol
With rods hanging out the side for authenticity :-S
Blocks are all gd and servicable. The 25 is bored to .5 ready for a set of rods and pistons and so is the 30 which is what will hopefully end up in my car!! Possibly... mabe.... lol
  • Like 2
Would be fearfull of any kizza beast:'(
In time!! Move into my new house 2 weeks today, cars half way down the list of jobs to do..... ?
  • Like 3
In time!! Move into my new house 2 weeks today, cars half way down the list of jobs to do..... [emoji52]
Damn responsible adulthood, been helping my mate Craig with his cortina. 250 yella Terra head, 500 holly, top loader 9" Tc xle. Seen that bad boy with the exhaust and brakes glowing red during apprenticeship.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
