Bugger, Pharkem chuck a sickie [emoji6]
95ltr v20 4400hp. Coolant tubes are 6", exhausts twin 14" up to 16" into a 48" muffler. 7 sets of each. Plus another 8 sets of coolant tubes and exhausts for varying engines. Got drawings and parts all over the place. Deadline 2nd week of January for the whole lot. No Christmas holidays. :@
1 hour ago, Beyond Blue R33 said:
11 hours ago, shoey85 said:
We are going to this, any one else keen?
Sounds good. I'll have to see how I pull up after another 53hr week. Feeling very old. On a deadline to finish the pharoes pyramid.
I know how you feel, moved houae at the weekend and been doing 4 hours ot a day. Working 6am till 9pm tomoz..... fml
  • Like 1
Money good, tax horrendous, body sore. New master and sleeved slave on clutch. Fork was fitted incorrectly and came off pivot ball. Gearbox out fork fitted correctly. New a/c compressor clutch was siesed. Now the clutch pedal has a weird click at different positions on pedal height. Assuming it's where the master cylinder shaft sits in the top of the clutch pedal.f##k
Sounds cool making custom bits for big boy toys
  • Like 1
That’s why they pay you the big bucks
I’m just a struggling Aussie battler
  • Like 1
Sounds cool and is fun working on big motors sifting though loads of drawings sorting and ordering flanges parts and bits. till you realise your a old man that also has to build it all. Cummins qsk95. Kta50's etc. Lithium and associated mining for batteries taking off. All jobs are for contract power management. Turning massive alternators for power generation. My Brother in law works for C.P.M. So always interesting mining and engine conversations. All the exhaust systems are like big meccano kits with slip joints on flanged bellows and lobsterbacks so they can be adjusted and welded on site out to the mufflers with stacks etc. I love the solid geometry and mathematics involved, parallel line, radial line and triangulation. but am getting too old to continuously pump out the big welding jobs. [emoji70]
17 hours ago, Beyond Blue R33 said:
Sounds cool and is fun working on big motors sifting though loads of drawings sorting and ordering flanges parts and bits. till you realise your a old man that also has to build it all. Cummins qsk95. Kta50's etc. Lithium and associated mining for batteries taking off. All jobs are for contract power management. Turning massive alternators for power generation. My Brother in law works for C.P.M. So always interesting mining and engine conversations. All the exhaust systems are like big meccano kits with slip joints on flanged bellows and lobsterbacks so they can be adjusted and welded on site out to the mufflers with stacks etc. I love the solid geometry and mathematics involved, parallel line, radial line and triangulation. but am getting too old to continuously pump out the big welding jobs. emoji70.png
so, who does your drawings and does he need help?
  • Like 1
Nope it's my office. No one smarter or better than me allowed in ever. I guard that office and computer like a ravenous pit bull terrier. Any chance to get off the floor and I'm in there. :-) air conditioner soaking up even a very mild sweat.
15hrs pretending to be a German might not be germain to the situation. Just try to avoid their porn. Sebastian vettel calenders everywhere :-o
boilys working up a sweat... no way
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
