yeh mate all good and been a long time, still pop in here now and again to see what's happening. good to see you got back into your old field of work. Im up at Telfer as a operator/ maintainer in the power station now.
At least it's close to home.
Smells like Fish, tastes like chicken. Has wool on it. R u sure that's what it is?
Did the man in number 4 steal trevs skyline. Never seen a man wearing moar yellow. A veritable lama/lobster matador if I've ever seen one.
  • Like 2
20 minutes ago, Beyond Blue R33 said:
1 hour ago, t_revz said:
They have beer....
Don’t worry
I'll have a draught for starters, German beer for mains, and a pale ale for desert. With a normal chips thanks, hold the gravy.
Parmi and a cider plz and thank you! Refreshing when its hot!!
  • Like 2
But I've never been to Japan, one on every Street corner. Like kangaroos.
  • Like 1
