Out of interest where would you put the auto flex? Assuming you're doing it yourself not looking at pics or posts? Before or after the cat? Would be keen to see all the pics of your build? Must be a insane machine? A veritable titan?
I have photos that show all of the exhaust except the front pipe where the flex joint was.
1 hour ago, TiTAN said:
She wasn't pretty. But she got the job done.
4" dump, 3.5" front with flex pipe, 3.5" cat with 5" body, 3.5" to the middle muffler, 3.75" to the rear muffler and a 4" tip.
25/30 with a gt3582, 394kw @ 26 psi and 90db @ 3500.
This is the exact setup im going for.... ? atleast i know what to expect ?
2 minutes ago, TiTAN said:
Expect that the 38mm height difference in the block is far more annoying than you think it's going to be.
I have a grinder, hammer, welder and a soldering iron. We can make 38mm work lol
Stirred in natural yoghurt before serving:-) yum
Jack wanted to make a Korma chicken curry today? I'll show you how mate marinate the chicken. Set it aside. Get the oil hot close to bubbling then ad the spices stir and only just spoon in a few pieces! All the chicken dropped out the bowl into the piping hot oil an whalla!DSC_0149.JPGDSC_0148.JPG
Jack wanted to make a Korma chicken curry today? I'll show you how mate marinate the chicken. Set it aside. Get the oil hot close to bubbling then ad the spices stir and only just spoon in a few pieces! All the chicken dropped out the bowl into the piping hot oil an whalla!DSC_0149.JPG.1e949b087f3dda053e6ca7f4cdb3b4f0.JPGDSC_0148.JPG.68d26367b6202780e3b0c0dde2c346c1.JPG
This is my hand, splashed the piping hot oil onto it. Chicken Korma with blistering skin! Yum!
Frankensteins monster, bolt of lightning to fire up that nasty s.o.b.!
Exhaust won't fit, intercooler piping won't fit, clearance to the clutch master cylinder is quite tight, cam belt covers need to be modded.
Wiring isnt an issue from memory, it's just anything that used to bolt onto the head or between the head and block are now 38mm too low/short/out of place.
Sounds like a giant ill fitting jigsaw. Im sure il gwt it worked out with a lot of swearing and cursing
OUCH
Blistered up yet?
OUCH
Blistered up yet?
Amazingly looks pretty good today. Did 1 hour of cold water on off till the heat disappeared. Wrapped in sterile cloth and glad wrap. Nurse said just put antiseptic on for 5 minutes then pat clean keep re laying dressing.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
