1 hour ago, shoey85 said:
Hey all!
How was the long weekend for y’all?
We looked at the R34, went to Ikea, tidied the garage, went to the PRS, then caught up with my olds for their anniversary. Thrilling weekend ?
Morning peeps. I rolled the 33 out the garage into the sun and rain for the day. Changed a transmission on a vu ute in the garage. Took my dad to the airport. And snuggled the dogs. Sums up my weekend. Off to Melbourne this weekend for training.... oh the joys, best behavior time ?
  • Like 2
More training on how to be a animal in a different city with like minded mechanics. Oops (technicians.) went to Dave's Friday night. the panel beaters done a sweet job on the mustang fastback rear quarter. Perfectly straight lines and blended the paint through the boot, front door and roof. It's a massive panel with a dead straight line and bull nose radius corner. 2 weeks. He sends them about 400,000 a year in work so, top job. Took my cymbals and double kick pedals over used his sons drum kit. We played music, listened to music, watched music and drunk bourbon till 5am (gold). It was my b/day Sunday so low key with the wife and boys, they made me a scotch fillet steak sandwich for breakfast and my wife bought me a meet and greet ticket for marky ramone (the drummer from the ramones) when he tours in November (gold). Went to Mandurah too see the olds Monday they have been away for 9 months so great to see them. (gold) kids bought me Guardians of the galaxy 1+2 on Bluray so we cranked the Yamaha's and Bose's up. Should be 4 on 3 off every week;-)
  • Like 2
Hey all!
What is the Prs?
1 hour ago, R33kizza said:
Is that tbe cause of ur charging issue?
Yes, indirectly.
The Car was having trouble starting because it wasn't getting enough air into it due to the blocked intake, which was draining my battery because I was constantly trying to start it up.
So, on Friday Im going to charge the battery completely, and then see if it holds.  According to Mark from C-Red my Alternator is putting out enough voltage.
  • Like 2
26 minutes ago, Manne said:
Yes, indirectly.
Well thats gd news, cheap fix hopefully
  • Like 1
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
